Old 06-24-2016, 01:47 PM
cashmorey cashmorey is offline
Default 129 getting to hot?
My cub 129 will start and run great till after about 20 mins of mowing then will not stay running till it cools off any ideas?
Old 06-24-2016, 01:53 PM
Sounds like the coil is going bad.
Old 06-24-2016, 01:59 PM
Ok, do I have to buy the one from Cub Cadet, or can I get one from the auto parts store?
Old 06-24-2016, 02:00 PM
You should be able to get one from the auto parts store.
Old 06-24-2016, 02:04 PM
Ok, awesome I've got one. I bought for it a while back, I'll try that one.
Old 06-24-2016, 02:05 PM
Just wanted to double check that it would work
Old 06-24-2016, 06:42 PM
Make sure it is the correct coil. You need a 3.5 ohm coil. Between 3 and 4 ohm is fine.
Old 06-24-2016, 10:53 PM
I had this issue once on my 122, ended up being the condenser. Switched in a new one, problem solved.
Old 06-25-2016, 01:44 AM
Thanks all its got a new condensor on it and put the new coil on tonite well see how she does tomorrow
