Old 06-18-2016, 06:51 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Default Brought home a 149
I finally got my 149 home that I bought a few weeks ago. Looked it over, and if this guy was using it weekly 1.5 years ago, I can see why he likely parked it.
Someone has been through this tractor and replaced and rigged a few things.
There was c-clamp holding one of the rear pins on the mower deck (which work just fine, so I don't even know what it was supposed to do. They've put bolts where the shoulder "frankenstein" bolts go. A guard is missing on one side of the steering tower. And there is no wiring to the headlights. The switch is there at least.
Overall it looks ok, and most things look minor to fix. The PTO won't disengage, but there is clearly piece missing on the front. I haven't tried to start it yet, as there isn't a battery. The engine turns freely and has compression, so I'm hopeful. I'm gonna borrow the battery from the 1200 tomorrow and see what happens when I crank it. Hopefully it fires right up
Worst case, it will be a good parts tractor for my 1200. The wheel weights, blade and chains are worth what I spent on it.
Here are a few pics. I'm sure I'll be back with some questions. Don't ask about the seat. He said it went too fast and threw him off, so he needed a taller back
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
