Old 06-11-2016, 10:34 AM
Daniel1962's Avatar
Daniel1962 Daniel1962 is offline
Default Front wheels for a 1200
Hello folks,
I need to replace my 2 front wheels, The bearing holes are all worn out,
I know there 3/4" bearings and 6.50 x 8
Will this wheel work
http://www.millertire.com/products/l...b-3-4-bearing/
thanks
Dave
1976 Cub Cadet 1200 & 44A mower
1964 Cub Cadet 100,
No Attachments at this time, I do have a cart to pull stuff around.
Old 06-11-2016, 10:41 AM
One of the reviews said the hub is to narrow so they had to use a spacer but he said it was a wheelhorse, you might want to contact Miller to see how wide the hub is before ordering.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-11-2016, 12:13 PM
JLM78 JLM78 is offline
Are you using Good bearings? I have bought some cheaper ones that fall out.
Old 06-11-2016, 12:48 PM
If you're short of funds you can wrap the bearing with appropriate thickness shim stock to fill the gap.
I have used aluminum drink can material. Not pretty but easy on the wallet.
Old 06-11-2016, 01:43 PM
Daniel1962's Avatar
I'll check with Millers on Monday, I had decent bearings, I'd rather just do it right and be done with it. There price is good, if I can make it work
Dave
1964 Cub Cadet 100,
Old 06-11-2016, 01:59 PM
I like that.........
Old 06-11-2016, 02:43 PM
The drinking of the beverage or the shimming of the wheel? Or both?
Old 06-11-2016, 03:14 PM
Or both?
Well, now that you mention it.........both.
Old 06-12-2016, 01:06 AM
bkw3614 bkw3614 is offline
Before you buy from Miller, you may wish to check with one of the sponsors, as listed above. They will have the correct wheel for your tractor, so no shims may be necessary, and very possibly will be cheaper than what you are looking at. They will also have the correct bearings.
Cheapest isn't always best, especially when extra parts are necessary to make them fit.
