Old 06-06-2016, 01:11 PM
three4rd three4rd is offline
Default 129 is taking more and more oil...do I need an engine overhaul?
Hi,
I'm assuming that, similar to a car, this is case of 'blow-by' with the piston? Before I mow each time I have to add more and more oil - currently about 1/8 quart or so I'm guessing. The engine was overhauled once a long time ago. I do seem to notice bluish smoke coming out of the exhaust as I'm mowing. What is the best advice? I don't mind tackling smaller, manageable jobs, but really don't have the time right now to do anything major. Have it trailored to my local dealer for the work?
Thanks,
Keith
Old 06-06-2016, 01:17 PM
Yeah, it needs overhauled.
It will cost you a small fortune to have a dealer overhaul your engine. If you can't do it yourself, you might be able to get a engine machine shop to do it for you, but again, it will be costly.
I did offer an exchange program, but right now life has me too busy to take on anymore. I have 2 or 3 sitting waiting for me to get to them right now. I might be able to help later in the summer if you don't get it done. Only other choice is to buy a used engine, or see if another member can help you out. kustomlawnandgarden.com does offer rebuilds at a very reasonable rate. Not sure about warranty, but that is you best choice if you want to pay for a rebuild. My prices are almost identical.
http://shop.kustomlawnandgarden.com/...ACTURED_c4.htm
Old 06-06-2016, 03:52 PM
Thanks. I'm sure it'd be expensive, but since I still plan on keeping the tractor I suppose I could check with my dealer on an approximate cost. I'm confident I could do it with enough instruction, but, similar to what you said, life is just too busy for me also to invest the time. Will it hurt to just keep adding oil for now?
Old 06-06-2016, 04:19 PM
Where in PA are you located?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-06-2016, 04:31 PM
Only hurt your wallet. (Which no more than it is I would say won't hurt bad.)
If you guys are close, I'd give this guy a holler ^^
Old 06-07-2016, 02:28 PM
Near Reading (Berks County)....about 4 hours or so away from you in Indiana. Why do you ask? Do you pick-up and repair tractors?
Old 06-07-2016, 04:42 PM
I'll do anything for money, well almost anything. but seriously I was just asking because I'm sure I can rebuild your engine far cheaper than a dealer can or I can rebuild an engine I have here.
Pap's 100
Restored 108
1211 Dual Stick
1050
