Old 05-14-2010, 09:01 PM
cub1200puller's Avatar
cub1200puller cub1200puller is offline
Default Hydro temp.
I was wondering how hot a hydro pump on a 1650 should get. I use it pretty hard. I mow about 3 hours at a time with it and it does have the fan on the drive shaft and it is turned the right way. It does not get to hot to where you cant touch it but it does get warm.
Old 05-15-2010, 07:55 AM
That is a hard question to answer since I have not seen any data on that.
The best you can do is, keep the Aluminum portion (Fin) area clean from dirt & dust. Check you fan periodically to see if it is still there and gripping the drive shaft,
The goal here is heat dissipation.
Old 05-15-2010, 09:12 AM
Amigatec's Avatar
Amigatec Amigatec is offline
I have worked on Hydrostats of bigger equipment and as long as you don't stall it out, heat shouldn't be a issue. If it does stall out it will heat up VERY quickly.
Pat Benner Haskell OK
Old 05-15-2010, 03:31 PM
If it helps, on my 782, after 2-3 hours of mowing the rear end/reservoir is as about as hot as you want to hold your hand on--105* I'm guessing. but no more.
Old 05-16-2010, 08:03 PM
57130's Avatar
57130 57130 is offline
I'd say just check that fan periodically. Bothe my 1450 and 149 had the m broken to the hub when I got them. Then I broke the one on my 1450 when something flew into it. They're a pain to replace but it's worth it.
Old 05-16-2010, 08:36 PM
maplekid maplekid is offline
How hard are they to replace? My cub 149's is beat up pretty bad. I probably should replace it also what do they cost.
Cubs 149 worker 125, 102, and 147 projects
2 blades, snowblower, soft cab, wheel weights, brindly plow, disk, 4 yard trailers, 2 sleeve hitches, tiller, scoop tote, and tow behind york rake
Old 05-16-2010, 08:38 PM
Amigatec's Avatar
If you stand behind the tractor you should be able to feel the air from the fan, hold your hand down there and you should be able to. I can on my 129.
