Old 04-28-2016, 09:08 AM
RedOnes's Avatar
RedOnes RedOnes is offline
Default 982 driveshaft specs
Hi gang ,
this forum has a plethora of information but I`m still trying to find the specs for a 982 driveshaft i.e. hole locations , length. I hope to modify a shaft from a 1872. It seems longer .....any help appreciated ...
Old 04-28-2016, 09:22 AM
Terry C's Avatar
Terry C Terry C is offline
I'm sure someone else can get you the answer sooner than I can, but
if not I have a spare driveshaft I can measure up but it will be Fri morning
before I can get to it. Sorry
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-28-2016, 09:36 AM
john hall's Avatar
I just copied my old one, didn't bother to make a print unfortunately. I did use 4140PH material though.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-28-2016, 10:36 AM
RedOnes's Avatar
No hurry, I moved the engine forward and squeezed the driveshaft in position and it seems to work but before I put a load on it ,I would like to be sure.
I went to the trouble of changing to a 3000 series driveshaft and that idea turned out to be a disaster. For some reason blue barrels went flying... Now back to rag joints. They can be a PITA to change on a 982 but seem more capable of taking the torque.
