Hi like I said the 547cc efi engine is surging when started at full throttle at low throttle it's fine when pto is engaged it's fine no idea why a brand new mower would do this. I called dealer I purchased from they said it's part of break in process and put a few hours on it and if it's still doing it they will come pick it up... I don't believe that since my dad bought same mower and his doesn't do that. What should I do? Thanks
Is it possible the fuel is old or has water in it? As long as it's under warranty I'd just do what the dealer says and put a few hours on it and go from there, regardless of what we say the dealer probably won't do anything for you until you try what they said.
FYI, my EFI performed amazing from first crank.
- Jason ________________________________ 1872 - Kohler 28hp EFI repower |
What model tractor are you dealing with?
Hi it's a 2016 xt2 Enduro 547cc efi
OK and what engine do you have? Kawasaki or Kohler?
It's a cub engine not kawasaki or Kohler and I don't start my car in full throttle obviously I do what Manual states which says start in full throttle
Cub doesn't make engines. It's either a Kohler or Kawasaki.
I highly doubt the manual says to start at full throttle. Even if it does, stop it!! It's not good for it. Get the dealer to make it right. No one here is going to be able to help on an EFI motor. They are computer controlled, and you have no way to read the information it is getting. Get it back to the dealer. |
I just spent about a 1/2 hour trying to find out who makes that engine and came up blank. What ever it is it's a vertical shaft single with injection and it's branded Cub Cadet.
