Old 04-23-2016, 11:45 AM
Default 1211 shakes
my 1211 has some awful vibration between idle and wot, i know this is to be expected with a single cylinder but i was checking it over last night and it appears the rear of the engine is down causing a misalignment. i checked parts tree and the iso mounts for this tractor are no longer available so i guess i will go with solid mounts but does anybody know if the solid mounts Jeff sells for the ql tractors will work? it looks like they have different part numbers. thanks
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-23-2016, 12:36 PM
I believe they will. I will go look at my tractor here after bit and compare to some QL stuff, but I'm pretty sure they will work. The ones on my 1050 are tight, so I've not been worried about them. When I go to put that new engine in, I was thinking I'd get a set and install them.
Old 04-23-2016, 12:46 PM
Tim,
cub cadet part # is 759-3952
still available from cub.
Up to 534 and counting...
Old 04-23-2016, 12:57 PM
the engine mount and iso mounts are completely different between the 1050 and 1211
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-23-2016, 12:58 PM
Tim,
the number from partstree is 722-3002, how did you cross over to that number?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-23-2016, 02:02 PM
That they are. Didn't realize that. Don't know why.... Interesting.
He looked up a 1282/680 which is the same machine. For some reason, the 1211 look up doesn't cross it correctly. I've seen that a bunch on these mid/late 80's machines.
I don't really know why the 1050 uses a different style mount. That's odd.
Looks like all the 82 styled machines are more like the QL's. I don't see any reason why the solid mounts won't work. I bet the only reason that the part numbers are different between the QL's and the later machines mount is that CCC bought them from a different manufacturer than IH did, or the are made out of another material. I would put money on that they are identical, except from different supplier.
Old 04-23-2016, 02:11 PM
That is why you should use the cub cadet parts lookup. Partstree sux
Old 04-23-2016, 02:37 PM
i checked cub cadet parts look up and it gave me the same part# as parts tree.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-23-2016, 03:11 PM
that is just for the rubbers,the other number is the kit.
I like saying rubbers. ...
Old 04-23-2016, 03:19 PM
Pap's 100
Restored 108
1211 Dual Stick
1050
