I have a Cub cadet 1250 and a engine out of a Cub cadet 1210 it is a magnum engine. I was wondering is this would be and easy swap. Install the magnum engine into the cub cadet 1250. I think the wiring is different but it looks like the engine will bolt up ok.
You will have to add a relay to control the engine shut down for the Magnum. That or change the key switch and do some rewiring. Relay is an easy conversion. It will be identical to what you do to swap a Mag engine in for a KT on (for instance) a 782.
Everything else is the same. |
