Old 05-11-2010, 09:07 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Default Took my grandson's tractor project frame to my powdercoater tonight..
After alot of thinking about what I wanted to do with it and how to paint it,I went a totally different direction. I was planning on painting it a silver color frame and suspension and a matching green to my racecar and add Lunar effect as well as a Marvin the Martian paint scheme,but after I thought about it, I decided I liked the IH red of the big tractors. So now, it will be IH red and white tower as well as white wheels. I am putting 8.50 AG's on the back as well as 4.80 front tri-ribs. Hoping to keep the motor either a 8 or 10 hp unit. I also will put a stack on it. I want to have a custom IH grille on it and make a panel where the headlights are and either have it cut out or painted with his name Carson on it. Planning on the QL series frontend so it will be a bit easier to adapt the plates on the front. I already asked a buddy who does decal designs about making some flat black hood and tower decals for it. When I took the frame down tonight,he quoted me a price of 35 to blast it and 65 to coat it Farmall red. When that's done in a week, I will take the wheels in to be done. I want to make a wider front axle and make it resemble a bigger tractor like I have seen on the net,but can't find the pics of the one the guy had on one of the forums.
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 05-11-2010, 10:38 PM
ihnick's Avatar
ihnick ihnick is offline
ive seen the 826 custom cub. maybe try googling that???
Nick.
Old 05-12-2010, 02:58 PM
JeffD JeffD is offline
Find out what sand he will be using to blast the frame. If it is really course, the powder coat will not lay down real nice. The smoother the better. After it's blasted, have it sanded with 180 grit paper on a DA. Tell him to turn the oven up a bit as it will make the powder "flow" a little better. All my stuff has been coated using Diamond Vogel Tractor Red, which, is a dead on match for IH red.
Also if you are talking about a narrow frame tractor just install a wide frame front axle, and spindles. Much better design. Going to do that with my 100.
Jeff
782 w/Honda power
129 stock for now...
100 basketcase
