Old 04-01-2016, 09:24 PM
farmall fred's Avatar
farmall fred farmall fred is offline
Default 1872 Rebuild & Repower
I am stating this thread to document the rebuild repower of my 1872. I bought this tractor with the idea of making it a dedicated snow blower tractor and after reading CRY2872's thread on his 1872 Kohler 28 EFI Repower I decided that I wanted to build this one into my main worker tractor with a Command 28 Hp EFI engine, three point hitch, three valve hydraulics with front and rear remotes and separate valves for three point and belly lift. I plan on painting it 2150 red with a black frame and belly and silver wheels. I am thinking of having custom decals made I think I will badge it as a 2882. I will then dedicate my other 1872 that is powered by a 23 Hp Kohler Command as my snow blower tractor.
Here are some pictures of what I am starting with.
It looks much better in pictures than it really is.
Notice the wall switch that was used to engage the pto. Also has new drive shaft with disconnect clutch. Problem is he ran it much to long with bad rag joints and ruined input shaft and coupler on hydro.
It does have a new PTO clutch.
Dented and cracked seat pan. I will replace with one from parts 782.
Mag 18 that is getting replaced with EFI motor. I worked on it today. replaced the coil assy, cleaned the carb, changed the oil and got it running well. The previous owner had it rebuild and he showed me the receipts. I pulled one head and it has been bored oversize and has had the valves and seats ground. I put an oil pressure gauge on it and it carry's 45 PSI at an idle hot and 70 at WOT. I think it will be ok to put in a 782 I have with a blown motor that is to good to part out The 782 will be getting a sickle bar mower and will be a dedicated ditch mower.
Pressure washed so I can trial fit engine. Mounting plate from 1864.
Missing bolts from rear end and damage to housings. I will replace with a cast iron rear or use rear from 1864 that has the 30mm axles. Either way I will have to swap reduction gears from the super rear end.
Old and new engines,
A second parts 782 I bought last week for sheet metal, dash plastic, grill and seat pan for 1872, and also any thing else I might need such as cast iron rear. Motor is blown and it is not a IHC made tractor. It has a replacement pto clutch and a new driveshaft so I will have some parts on it to use on my sickle bar 782. Will probably use the tires also on it. Tomorrow my grandson will be helping me tear down the parts tractor and also put the Mag 18 in the other 782. Right now I have three cub cadets and my 57 Chevy project in the shop and it is getting crowded. As soon as the two 782's are gone I can start on the 1872.
I welcome any suggestions or constructive comments.
Later
Tom
Old 04-01-2016, 09:57 PM
samckitt samckitt is offline
Looking forward to seeing this come together.
Old 04-01-2016, 10:32 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I'm looking forward to following this thread!! Take lots of pictures and keep us posted!! Looks like a great project!!
Jay
Proud owner of the following:
Old 04-01-2016, 11:40 PM
Great, another build to follow Looking forward to the progress reports...
Old 04-02-2016, 08:04 AM
Thanks guys, I will post progress reports as time allows. Won't be long before I have to start spring planting on the farm. I hope to get the engine wired up and running before I start just to check it out in case there is an issue with it as it was a warranty engine that was repaired by a dealer.
Today the grandson and I will do the teardown on the parts 782 and hopefully I can get the Mag 18 running in the other 782, guess I better get off this computer and get busy.
Later
Tom
Old 04-02-2016, 10:02 AM
longislandcubs longislandcubs is offline
Smile
Good luck, look forward to seeing it come together.
Old 04-02-2016, 11:02 AM
Here is a complete rear and pump out of a 2182.
Cub Cadet super rear end complete - $650 (Statesville)
http://charlotte.craigslist.org/grd/5518236084.html
I checked the phone number and it's being sold by one of our inactive members. Methos AKA Duke Carpenter
Old 04-02-2016, 11:13 AM
Looking forward to your progress and updates!
Old 04-03-2016, 11:18 AM
Sam, thanks for the tip on the rear. Before I buy anything I need to tear down my hydro pump and rear and see if I can salvage or repair it. I also have a Cyclops rear from a 1864 that I can possibly swap my reduction gears into or if my input shaft is salvageable swap my ring and pinion and carrier into a cast iron rear I have. Yesterday the grandson and I tore down the parts 782, I then set the Command engine in the 1872 and put the rear fenders, hood and grill from the 782 on it to see what it will look like red. Think I am going to like it. We then set the Mag 18 in the sickle bar 782 and changed the filter and drained the rear and refilled it with fresh Hytran. Today hope to start it up and if all checks out, replace the sheet metal and drive it out of the shop. This will giver me some working room to work on the 1872. After I get a chance to start the Command and check it out I will then finish dissembling it and prepare the frame for painting. Will post some pictures tonight when we get back in from the shop.
Later
Tom
Old 04-04-2016, 07:59 AM
Tom
If you go that route you will need to swap both the reduction gear and the pump output shaft. The shaft for the super is different between the GT pumps and the SGT pumps.
