I have seen on a old post that some one Drilled Drain hole in the rear end case to drain the axle tube.
Sam Mac has it in one of his threads
If you have the rear out of the tractor and the axle tubes off the center section it's an easy job. If the rear is still together in the tractor then pull the axels and use a suction gun to suck the water out of the tubes.
I'm Working on the rear end for the other 1572 . Its out on the work bench with axle tubs off .
Easy job, a 3/8" drill and you drill 1 or 2 holes at the lowest portion of the case. Depends on the design of the housing. Some have a hump at the bottom and they need 2 holes. Later cases don't have the hump so 1 hole is enough. Pic I posted has the hump and it got 2 holes. This pic is a later housing with 1 hole.
Got them drill . Just waiting for the new seals Thanks sam
