Old 03-12-2016, 07:33 PM
Penglish Penglish is offline
Default Governor Cross Shaft
Hello everyone, this is my first post and I am not a Kohler or small engine guy.
My late 70's engine is in a bad place and I hope to save it with your help. The bolt that holds the governor cross shaft in came loose. I noticed the problem and tightened it up. I must have messed something up because now the engine starts but has what seems like timing problems when I give it fuel.
Do you think I need to pull the whole thing apart? Or, is the some way to put the shaft back in the correct way without opening the case?
Thanks, Paul
Old 03-12-2016, 09:07 PM
CubDieselFan's Avatar
First of all. Welcome to Only Cub Cadets. I do not have any knowledge on the engine you are working on, but someone with the knowledge will be along shortly. Again, Welcome.
Old 03-12-2016, 10:01 PM
I'm sorry but I missed where you told us what you are working on.
Is it a cub cadet? what model? what size engine?.
It might help as we don't like to assume anything, as too many variables.
Old 03-12-2016, 11:07 PM
Ditto.....
Old 03-13-2016, 10:12 PM
Smile
The engine is a 16 HP, Kohler.
The cub cadet is a 1650 model.
Thanks for the assistance,
Paul
Old 03-14-2016, 12:48 AM
The governor cross shafts is held in with a nut. The governor arm is held on with a bolt.
Now, what is it that came loose?
You may need to readjust the governor. The Kohler K series engine manual tells how to do this. You can find it in our "Resources" section on the home page. It can be found under the heading "Technical Library, Tractors".
Tags
governor
