Old 03-11-2016, 10:04 AM
GravityBad GravityBad is offline
Default LT1042 rear wheels will not move freely
I purchased a LT1042 about 8-9 yrs ago and used it for 3 Louisiana summers before storing it for the last 5 years. I'm assuming the issue has do do with the long term storage as it has only 83 hrs logged and was running fine prior to it being stored. After a recent move to SC, a large yard, and springtime upon us, i pulled out the CC to tune it up for the season only to realize that the rear wheels are locked and will not move. The wheels will not move freely with the hydrostatic bypass engaged into neutral. The bypass actuator lever/linkage looks to have the correct throw and all other linkages, including the brake, look to work properly. I came across a LT1042 parts manual that stated 'IF' you're transmission has a drain plug...apparently mine does not as it should be located directly under the actuator lever. I assume the drain plug is incorporated into he higher end Series 1000 models and not the base LT1042. I currently have the rear end jacked off the ground and the wheels move freely simultaneously in opposite directions.
The rear wheels being locked was a real problem when trying to load this beast into a 26' Uhaul for the move! To add insult to 'literal' injury, the front tire was flat, my air compressors were already buried behind 15' of accumulated treasures, and i had to load it by myself....
Ive found limited information here and through other sources regarding this issue. Any thoughts or guidance would be much appreciated.
Thanks,
Joe
Old 03-11-2016, 11:08 AM
My guess is that the disk brake is rusted to the brake pucks. Brake is on the right side of the trans as your sitting on the machine. If you can get it running maybe you can get it free by trying to move it forward and reverse.
Old 03-11-2016, 02:31 PM
Sam Mac,
Yes, i believe you're correct about the disk brake. I just noticed this potential issue and was about to post a follow up.
I disassembled the brake parts to see what was going on. With the disk brake housing nuts loosened, the axle will rotate forward and reverse for both wheels simultaneously. I just need to clean the rust and junk from the brake unit, get a battery, and get her running again. With the way my luck was going with this move to SC, i jumped the gun and assumed the worst by thinking it may be the hydrostatic bypass.
Thanks for your reply and suggestion as it was spot on!
Joe
Old 03-11-2016, 03:42 PM
Glad to help. Every once in a while I get one right. Let us know when you get it going if it works.
Old 03-12-2016, 10:22 AM
LT1042 back in service...working perfectly. SamMac - you were right. the 'pucks' were frozen/locked in place with the disc pads sandwiched tightly around the rotor. A little disassembly, cleaning and a new battery and she's back in action. Started and ran perfectly form the moment i hit the ignition.
Thanks for the quick response,
Old 03-12-2016, 05:51 PM
Glad to help, that's why I get the big $$$.....I wish. Not often we get a thank you so just want to say it's appreciated. Happy Cubing.
