Old 03-07-2016, 02:15 PM
OneBadBinder OneBadBinder is offline
Default NF PTO set screws
Been trying to yank the PTO clutch off my 125 and not getting anywhere. The Allen wrench isn't biting on any thing and I am beginning to wonder if someone tried to drill out the set screws before I got it. Take a look at the pics and see if you agree. I really don't want to drill and easy out the darn things.
-Wes
'67 125 48" Deck, 1A Tiller, 36" Snow Thrower, Push blade
'03 2166 42" Deck
Old 03-07-2016, 03:43 PM
That can't be a pic of the set screw. They are down a hole.
Old 03-07-2016, 04:06 PM
That is down the hole
I have pictures down the other two holes that look just like it.
-Wes
'03 2166 42" Deck
Old 03-07-2016, 04:18 PM
That is a picture down in the hole for the set screw? Are we seeing the same pic? That looks to me like a rotted off top of a bolt, not a pic of a rounded set screw down a 1/4" hole.....
I'm not convinced that you are working in the right place.
Old 03-07-2016, 04:38 PM
Is that the basket pulley in the top half of the picture?
If it is, is that a crack in the basket on the left side of the hole?
If it is, you may be better off to cut the basket, then bend it back, so you can take the lock collar off the bearing and remove the pto (bearing and all).
That should make it easier to get the set screws out.
Can you get a picture a little further back so we can see a little more of what you're dealing with?
Old 03-07-2016, 04:47 PM
Maybe I can't see all the pics? I only see one......
Old 03-07-2016, 05:38 PM
Sorry I did only attach the one, figured you would want a close up shot as opposed to the whole basket.
-Wes
'03 2166 42" Deck
Old 03-07-2016, 05:39 PM
The pics uploaded sideways so.... the basket is on the bottom of the pics and the set screw holes are dead center.
-Wes
'03 2166 42" Deck
Old 03-07-2016, 06:04 PM
Yeah, the pictures are too close, we can't tell what we're looking at.
Old 03-07-2016, 06:14 PM
REDDHOGG REDDHOGG is offline
One bad i think your in the wrong place,the set screws are in the clutch ,cast part, the hole is a notch in the eadge of the basket .may have to turn clutch inside the basket by disengage the clutch to line up set screw holes.
