Does anyone know how thick the metal is for a 42" blade, the piece that is curved. I had to cut a piece out and need to weld a new one in so I need the thickness of it.
1961 Original 1962 original w/ fenders and creeper 102 72 w/ fenders and lights 124 w/ sleeve hitch 129 w/ lights 5 mower decks, 2 plow blades, 1snowblower ![]() ![]() ![]()
its just .125" isnt it???
I doubt that it's that thick. Think he's talking about the face of the blade. Just measure your existing blade.
Edit: Red neck way to check the thickness, take your Metric Adjustable Wrench, close it down on what you want to measure the thickness of, then take your feeler gages and see what fits between the said Metric Adjustable Wrench jaws and you will have a close measurement of the thickness of the metal of your blade. If you have a set of calipers you could use them to measure the metal thickness, in that case you can disregard the above instructions.
