Old 05-07-2010, 02:35 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Default 4.80 wheel differences.Do some use bushings?
I horse traded for a set of 4.80x4 rims for Carson's tractor and didn't notice until I got home that 1 has bearings inside and the other looks to use bushings. It has a 1 inch hole or bigger. Since I want to put 3/4 spindles on,and use tri ribs,can I buy the bushing? Maybe someone has one for sale. What are my options? These are really rust free and I'd like to use them..
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 05-07-2010, 03:44 PM
The CCO was the only model that used "bushings" in the front Rims. From the 70/100 Series and newer, ball bearings were used.
Old 05-07-2010, 06:03 PM
bignastyGS's Avatar
Are new bushings available? Or should I have one made for me? Maybe I could even swap even up if someone needs a nice rim..
Pat Harmon
Loganton,Pa
128 Cub Cadet
LT 1042 Cub Cadet
1200 Cub Cadet
1941 John Deere H
Old 05-07-2010, 07:41 PM
Lonestarcub Lonestarcub is offline
Default New Bushings
Pat,Go to CC specialties and look under the wheel & tire section and their listed brand new for $9.00ea.
Good Luck,Bruce
Old 05-07-2010, 09:44 PM
juniors1282's Avatar
Default bearings
Pat if you want to change to 3/4" spindles just swap out the bushings for 3/4 bearings you can pick them up from your local cub dealer. They aren't cheap but work much better than bushings. I believe the bushings have a 7/8" hole, and I believe the bearings are 3/4" hole with a 1 3/8" od. I have the bearing part number from cub hear somewhere I'll look for it and post it for you.
1966 IH cub cadet 102x2
Old 05-07-2010, 10:46 PM
johncub7172's Avatar
I got my fronts of my 72 for a 100$ each from my local IH cub cadet dealer.That was new rim, inner + outter bearings and tire. But on my 71, the tires are still original and in "tip-top" shape even after all these years. So to say you could still find these parts around.
