Old 01-24-2016, 07:46 PM
Lucky Chow Lucky Chow is offline
Default Cub Cadet 125
As some of you know, I picked up this 125 about 3 weeks ago from a gentleman in Tennessee. It showed up on Craig's List and I made a call a couple days later. He still had it so I made arrangements to go see it. It was about an hour and 15 minutes from my house. I ended up buying the unit thinking it was a 105 instead of the 104 that was on the hood. I knew it wasn't a 104 since it was a hydrostatic. Little did I know how wrong I was, when Tim E said some things didn't look right for it to be a 104. Turns out to be a 125, which makes me even happier.
You've seen this before, but here it is coming home being pulled by my Prius V wagon, which Olds45512 referred to as my "hair dryer", lol.
So now it's time to start making repairs to things that have been neglected. Since the tires looked to be dry rotted and original, I ordered new tires and have already had them mounted and they're on the tractor. There was a lawn mower shop up the road that charged me $12 each and I took them up on that deal. Sometimes it pays to outsource some things even though I could have done it myself. They had a tire machine and I would have spent a long time getting those done. I also ordered some other parts that will be replaced as soon as I can get to them. Here's a few sitting on my cart waiting to be installed.
This afternoon I pulled the wheels off the front to install new bearings.
The wheel bearings were pretty sloppy. However, that's not the only slop there. The spindles have quite a bit of movement in the axle. I know I can buy new spindles, but is there a bushing in the axle too? When they are worn, is it usually just the spindle or does the axle also wear? If someone can point me in the right direction for this fix, I'd appreciate it.
Here's some pictures replacing the bearings. After removing them from the wheel, I pulled a rag through the axles to remove all the old grease. The new bearings are sealed, so I'm assuming there is no way (or need) to add any additional grease.
Please excuse the dirty wheel I'm working on. The weather has been so bad since I bought it, I haven't been able to wash it yet.
That's it for today. Hope to get more done this week since the weather will be a little warmer.
Darryl
IH Cub Cadet 125
Old 01-24-2016, 07:58 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Oil in plastic bags? Intravenous feeding? Intensive care? Com'on!!!!
You will like that 125. Ask me how I know! Your 125 looks good!
Plow blade
#2 Cart
QA36 snowthower
Old 01-24-2016, 08:01 PM
Looks good.
Old 01-24-2016, 08:04 PM
Rmowl's Avatar
Rmowl Rmowl is offline
That's a nice looking 125, congrats! I haven't seen the oil in a bag either! As far as the spindles, my 782 has bushings in the axle but the narrow frames do not. I had a spindle sieze up on the 124 to the point where I ended up getting a new axle, anti siezed all of them after that
-Rick
IH 782
IH 126
CCC 1863
Old 01-24-2016, 08:05 PM
Ha! Ha! I was shocked too!
Darryl
IH Cub Cadet 125
Old 01-24-2016, 08:10 PM
As I posted before, I like the 125 model so much I have two of them.
Look on the insides of your rims, there should be a grease fitting there. That's how you add grease to them.
Jeff
Old 01-24-2016, 08:23 PM
Jeff
Thanks Jeff! You just sent me down to the garage to check that out. . . . .
These do not have a fitting on either side of the wheel for the spindle. There is one on the axle for the vertical part of the spindle. Could these be replacement wheels that were of lesser quality??
Darryl
IH Cub Cadet 125
Old 01-24-2016, 08:52 PM
a cub being pulled by a prius? oil in a bag? what will you come up with next?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-24-2016, 09:06 PM
How does that hair dryer pull (and stop!) the trailer & cub?
I like it. 125s are one of my favorites too. We (the kids and Dad) wore his 125 out. We rebuilt the motor 3 times in the 31 years I've been alive, and countless repairs & new mower decks, and she keeps going. Awesome little machine. 4 kids beat on it and it keeps on going.
Old 01-24-2016, 09:47 PM
john hall's Avatar
So should I take my unopened quart bottles of Low-ash oil and hide them away since they are now collector items? About how much did you get charged for the oil? I need to get near a Case-IH dealer this spring and get a case.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
