Old 01-16-2016, 11:35 AM
firensmoke21 firensmoke21 is offline
Default Cub Cadet 100 Hood
Does anyone know the dimensions for the hood brace on a CC 100? The previous owner attempted to fix it and I would like to make it right. I don't know the true dimensions being that it is separated on the one end. I'll probably have to fabricate a new one.
Ben
1965 Cub Cadet 100
Old 01-16-2016, 01:15 PM
IHinIN IHinIN is offline
I made one for my 100 since the original brace had been replaced with a homemade bolt-in brace. Mine is 12 or 14ga x 3" wide. It needs to be welded in at an angle to clear the battery and gas tank as the hood is opened and closed.
Old 01-16-2016, 01:18 PM
How long is it from side to side?
Ben
1965 Cub Cadet 100
Old 01-16-2016, 01:58 PM
It measures 13-1/8" and the ears on each end are 1".
Old 01-17-2016, 12:16 AM
Just cut that crap that's on there off and measure the width of the inside and add two inches. Easy peezy.
What I did to keep it in place for welding was to run a ratchet strap around the hood an tightened it up, positioned the cross brace and welded.
I drilled three holes on the brace at equal spacing on each end then welded the holes shut, a little at a time so not to get the hood to hot.
