Guys I know tires have been talked about a few times but I haven't really come across a definite answer for my circumstance , sooo here goes. After the flooding season there is a good amount of mud left behind, I have the 1872 with the johnny bucket to clear the mud. As it stands right now I use the tractor for digging, leveling and other dirt work. I run turf tires, cub cast weights and chains year round with pretty good success but the thick wet mud adds a whole other challenge. This leads my to my question will the benefits of the bar tires out weigh the cost spent on them? Is there that much of a gain versus chains?
I think a good set of ags will help out greatly, I know alot of people recommend Carlisle's but the deestones work great and are much cheaper. I had deestones on my 108 and I never had an issue, I did switch them out for Carlisle's but only because I got a new set as part of a trade and after having run both I don't really notice any difference in traction.
My choice would be 26X12X12 Tru-Power or Firestone ag tires on 10-1/2" wide rims filled with fluid.
Just looked at the Miller tire page and I see that they have a tire I have never seen before. 26x12.00-12 Carlisle WT300 4 ply
http://www.millertire.com/categories...s/26x12-00-12/
My local guy says about $45.00 per tire to fill will get me about 35 lbs. I cant find washer fluid in bulk I think I should be able to get more in there by breaking the bead as others on the forum have suggested. Nice tires and cub by the way.
Any parts store can sell you washer fluid by the case, there's 6 gallons in a case and I usually pay $12 a case. When I filled my 23x8.50s it took 6 gallons per tire and I guarantee its more than 35 lbs.
About 51 lbs? at the weight of water at 8.8lbs per gal? I don't know what method he's using but I was surprised that's all he could get in there
Loading the tires is easy. I just have my tire guy break the bead on the valve stem side, lay the tire on it's side and pour what ever your using in. Last set I did I got used anti freeze for FREE from the local shop. Used about 10 gals per tire. The wooden wedge holds the side wall down while I fill it.
