Old 01-14-2016, 12:40 PM
Terry C's Avatar
Terry C Terry C is offline
Default CH 25 in a box
Well I took it out of the box to mic everything and it looks ok except the cam which whoever took it apart didn't oil or cover. The crank was oiled and in a bag.
It's going in a 982.
So if you've ever wanted to see way inside of your CH, here you go!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-14-2016, 12:54 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Seems like the perferct engine for a 982!! So tearing it completely down makes it cheaper to ship??
When you sliding it in the 982?
1- 1200 in pieces
1- 1864 in pieces
Old 01-14-2016, 01:02 PM
Terry C's Avatar
Couldn't tell why it was tore down. Package deal so there isn't much as far as $ in it. I was pretty pumped about it till this:
Ordered a new cam it was 80$. Small price compared to the rest of the things
Terry
3225
Old 01-14-2016, 01:37 PM
You may want to replace the lifters also so that they break in against the new cam.
Old 01-14-2016, 02:01 PM
Terry C's Avatar
You bet. The look like they came out of a small block Chevy
Big 14% off sale of .010 Pistons and rings. Yeah..
I didn't think 150 was bad for piston and rings
Terry
3225
Old 01-14-2016, 02:24 PM
I would have polished that cam and ran it. Surface rusted.... it isn't hurt.
Old 01-14-2016, 02:27 PM
Terry C's Avatar
I can't tell if you are joking or not
Terry
3225
Old 01-14-2016, 07:36 PM
I thought the same thing- an electronic cleaner or equivalent to clean it up
Old 01-14-2016, 08:05 PM
Serious. I would have polished it on an extra fine scotchbrite wheel.
Old 01-14-2016, 10:02 PM
Serious.
Just like Jeff said.... Scotchbrite pad/wheel or take it to a crank/cam shop, or anywhere that sends cam/cranks out and have it polished just like you would a crank. Electrolysis cleaner is a good option. Honestly, if it was in my hands, I'd bead blast it everything but the lobes and those I'd hit with a fine grit cloth. Don't scrap it, it's still good. I have about 10 laying around like that that I plan to use if necessary.
