Old 05-04-2010, 05:46 AM
ChevyDan ChevyDan is offline
Default Shifter
Hello, I have a 1967 Cub Cadet model 72 with a standard 3 speed transmssion. Something broke in the shifter, it moves from side to side now, I can still shift it if I keep the shifter heading forward, I think I broke a pin or something like that. Has anyone run arcoss this before, I have'nt pull the shifter off the transmission yet to see whats in there and where might I get a new pin if it did break one? Thanks, Dan
Old 05-04-2010, 09:16 AM
Old 05-04-2010, 09:34 AM
johncub7172's Avatar
Welcome to the Only Cub Cadets site! Sounds like it could have something to do with the shifter fork? Someone will come along who can help. I have found Folks here know their cub cadet tractors, are friendly, and are great to get to know! thanks, John cub 7172
Old 05-04-2010, 09:39 AM
toyman's Avatar
toyman toyman is offline
From the main page go to the "Technical Library". About 2/3's down the page you will see a 3 part post for "Gear Shift Repair". Pretty simple fix, I fixed the shifter on my 70 last year. That should be all you need to get it fixed!
Original Member #54
Old 05-04-2010, 10:41 AM
camarokidz28's Avatar
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Old 05-04-2010, 10:55 AM
CC Rider's Avatar
CC Rider CC Rider is offline
Good to see a fellow Vermonter
Tom
CC's - 108, 122, (2)124, 149, 1320
Old 05-04-2010, 03:54 PM
Hello, thanks for the information. Am going to try and find a used one for now, what other model shifter will fix this 72 if any? Thanks, Dan
Old 05-05-2010, 01:56 AM
cubby cubby is offline
welcome,, any of the 60s 70s gear shift will work,, however ih made tese things simple to fix even if you havent a lot of mech experience. easy follow how to in the manuales and a few tools. you can fix and the sponces can help with the parts and any how to do this or that, just a thought. best wishes good luck
Old 05-05-2010, 01:57 AM
also they are the same trans thats in the larger tractors
