Old 12-16-2015, 02:01 PM
Wayne Wayne is offline
Default Tell me it isn't the clutch
Because the one time I worked on my clutch I swore I'd never do it again. I'm not that good of a mechanic and it was a PIA.
My 108 stopped moving. I was just able to coax it into the garage by holding the clutch pedal at a certain, partially depressed spot. Snow is heavy, I lost my job and have literally NO money for parts and I have no heated space to work on it. So like I said...
...tell me it isn't the clutch. Unless whatever it is is even worse than the clutch...
Cub Cadet 2166
Old 12-16-2015, 02:14 PM
From here it doesn't look like the clutch.
But, then again, you gave no usable information, no pictures.....
Read this:
http://www.onlycubcadets.net/forum/s...ad.php?t=35261
Link to the manual:
http://www.onlycubcadets.net/forum/s...ead.php?t=4644
Old 12-16-2015, 02:40 PM
I don't know what more I can say. I was plowing, and it stopped moving. The only way I could budge it back into the garage was by nursing/feathering the clutch pedal at a partially depressed spot and it creeped slowly into the garage, just barely.
I've told you everything I know.
Cub Cadet 2166
Old 12-16-2015, 02:43 PM
I'd pull the tunnel cover off and check the spiral pins where the driveshaft goes into the rearend.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-16-2015, 02:50 PM
I'll do that as soon as I stop crying.
Cub Cadet 2166
Old 12-16-2015, 02:51 PM
Userj8670's Avatar
Beat me to it. Had the same issue and it was the rear most spiral pin on my drivshaft
Old 12-16-2015, 02:57 PM
Were you able to coax it into slow motion like I did?
Cub Cadet 2166
Old 12-16-2015, 03:09 PM
I can't speak to his experience but I can tell you that when you push the clutch down it pushes the driveshaft back against the rearend and that extra bit of friction could be why it moved when you pushed the clutch down a bit. I'd go pull the cover and start the tractor and try to move the tractor, keep a good eye on the shaft going into the trans to see if its spinning, its usually the rear most pin that breaks first and if you replace one you better replace both.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-16-2015, 03:12 PM
cubby102's Avatar
cubby102 cubby102 is offline
I'm willing to bet it is the rear most Spiro pin also! Good luck with it
Old 12-16-2015, 03:40 PM
I'm a bit confused (not uncommon). But the shaft spins even when its in neutral
so I'm not sure what I'm looking for when its in gear
Cub Cadet 2166
