Old 12-06-2015, 12:10 AM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
Default 582 question
Is there any known problems with the transmission in a 582? Are they a cast iron version of what is in a 1050? Going next week to look at a future project if I get paid for a couple of jobs I am working on.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 12-06-2015, 12:17 AM
the rear end will look just like the ones in the older gear drive cub, not sure what the 1050 rear end looks like.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-06-2015, 12:26 AM
RR1862CC's Avatar
1050 is alum case with outboard disc brakes. I should also say it is 582 not 582 special.
Allis Chalmers 416
Brinly 10"plow
Old 12-06-2015, 12:27 AM
yea i figured but is the housing shaped the same as the older cubs?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-06-2015, 12:41 AM
RR1862CC's Avatar
Have not been to look at it yet. Just knew they were three speeds and was wondering if they were the same. I forgot they had wet brakes.
Allis Chalmers 416
Brinly 10"plow
Old 12-06-2015, 01:22 AM
They were built with both types depending on the year. Are you looking at the one in East Ridge? If so, that one has the CI rear.
Old 12-06-2015, 01:38 AM
RR1862CC's Avatar
That is the one. Just need to find time to get down there. Actually looking at another brand tractor as well. It is going to be a repower project if everything works out. The engine is part payment for some work I am doing. Perkins 2 cylinder 14 hp diesel. I took some measurements from my 1811 and it should fit. Might just put the engine back until later but saw the 582 pretty cheap. The other one is a freebie so that is even better.
Allis Chalmers 416
Brinly 10"plow
