I'm looking at a 123 cub cadet has new rear tires come with tiller but the flywheel is broke but comes with a new one
The tiller is worth a couple hundred bucks if it's ALL there, and everything turns free.
If it doesn't start and run it's still a NON running Cub, no matter what parts it comes with. I'd be more concerned as to why some knot-head left the air cleaner off. If the 3 point hitch is all there and it has a manual lift, the tractor is worth $150.00/$175.00 plus whatever you're willing to pay for a pair of new, used tires.
Any 123 is priceless!!
![]() Just kiddin'. The rear tires are ag tires, 8.5's I believe, and it has a somewhat new coil on it, but the muffler shield is not there, nor the grill or headlight/block out panel. I would probably go slightly higher than Mark and put the top value of the tractor (as a non-runner) at $225. He's on the money with the tiller, especially with a solid gearbox. EDIT: Frame is cut for quick access to driveline, so for me that would be a deal breaker....forget my above price.....No more than $150 for the tractor. Cub Cadet 123
I agree with 150. Maybe 200 if the tiller and rear lift are good
It needs some love.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
id be most concern about how the heck they broke the flywheel and if the rest on the engine any good.
I guess the reason why the flywheel broke/cracked was someone welded the drive shaft and it was out of balance or so I'm told
I'd pay $150 for the tiller and ask if I could have the tractor too. Looks like a lot of work to bring it up to shape. Only way I'd pay the prices discussed is if the attachments came with it. Otherwise, looks to me like a $50 (tops) tractor.
I wouldnt pay more yhen 250 for the whole package..
No more cubs. But never fear there will be more ![]() ![]() ![]()
