Bearings seized on PTO clutch. Ordered factory part called for, 917-3389 (got Stens 255347). Here's the issue:
Bad one has a slotted tab that fits over a shouldered stud for anti-rotation. Bad one is about 3" deep. There is a 5/8" sleeve bushing spacer behind it that is inward chamfered at engine side. Bad one is a Stens 255431/Warner 521829. New one is WAY different. Is 3.5" deep with no anti-rotation tab. From what I've found, looks like uses a "torque bracket" for the anti-rotation. Assume my (used) tractor been retrofitted? Are there threaded bosses on engine for this bracket? Can I make one out of a piece of angle? Don't I need a spacer bushing between engine and clutch? The old one is way too wide, would make depth over 4". Also, since the engine shaft is only 3" long, does the mounting bolt/washer pinch the clutch to the shaft? Any help is much appreciated. |
