Old 10-29-2015, 04:54 PM
gary11501 gary11501 is offline
Default Snow Plow Help
I have an Original Cub that I have had since it was new and purchased in April 1962. I am looking at removing the manual adjustment from the snow plow angle and replacing it with something that could be controlled from the seat. I have looked at 12v linear actuators, but not sure what size I would need that would take the force of push and would have some speed in operation like about 1 to 2 inches per second. My Cub does not have hydraulics. Any body have any ideas or should I just stay with the manual tilt? Picture shows the snow plow I have.
Old 10-29-2015, 05:05 PM
I would stick with the manual adjustment, unless you by an expensive heavy duty actuator. I don't think it will take the abuse.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-29-2015, 05:49 PM
I would leave it as delivered just because it is worth more as factory built.
Old 10-29-2015, 07:47 PM
Might want to PM Tim Crutcher depending where you're at in KY. He's quite the fabricator and would possibly have some ideas. Nice Original blade btw
Old 10-29-2015, 08:26 PM
Thanks for the ideas. I do not want to do anything that can not be reversed without changing either the integrity or the original design of the plow. If I went with an actuator, I would design it to fit in the existing holes and bolts. Thanks again.
Old 10-29-2015, 09:05 PM
You could look for a different blade from an early NF and use it instead of the original one. Besides, that one looks too good to use!
Old 10-29-2015, 10:09 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
I did thatabout 4 years ago with my 1864. Had a pretty decent actuator and it did not hold up!! Stripped it out and bent it up like a pretzle. Mr Manuel angling is best next to hydraulic!
1- 1200 in pieces
1- 1864 in pieces
Old 10-29-2015, 10:12 PM
Thank you for the information. I will check it out. As far as the looks, I am restoring my 62 original and had just finished with the plow. I agree, it will be hard to use and get the first scratch on it.
Old 10-30-2015, 10:09 AM
Berwil's Avatar
Berwil Berwil is offline
I have the spring trip plow on my O, it uses the same spring pin with corresponding holes for angling as regular narrow and wide frame blades. I have been toying with the idea of attaching a cable to the spring pin to disengage it from the seat. To turn it, my idea was to use the nearest snow pile to push or pull the blade to the angle I wanted, then release the cable, letting the pin lock itself when it found the nearest hole. A little cumbersome, but better than getting on and off a dozen times.
I would think you could recreate the bar in tube adjuster that your blade has and add a cable operated, self locking pin. Then you can angle it from the seat as I described above. Follow the McMaster link for a spring pin, I don't think that specific pin will work for you, it's just to illustrate my idea.
Again, I don't know if this will work in the real world, just an idea I had as I got back on the tractor for the umpteenth time.
http://www.mcmaster.com/#8498a66/=zlbp0i
Bill
Old 10-30-2015, 04:39 PM
Good idea. Something else to consider. Thanks
