Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 10-26-2015, 03:15 PM
a3v03v0's Avatar
a3v03v0 a3v03v0 is offline
Default Does this engine work in a 582 ?
As part of a larger purchase I ended up with a briggs 402417-0687-01.
From what I can see online the 582 used this engine. Am I right in thinking that with the right motor mount plate it will fit a 582 or maybe any x82 ?
What else needs to be changed ?
Old 10-26-2015, 06:07 PM
Check with Roland, he has the engine codes.
Old 10-26-2015, 06:15 PM
The 582 rolled out of the Factory with a B&S model: 402417 Type: 145-680
Old 10-26-2015, 07:43 PM
a3v03v0's Avatar
Thanks
I should have done more research prior to asking about switching engines. It looks like it is impractical to do a switch with all the parts that are specific to using this engine.
