Old 10-25-2015, 10:53 AM
Danej540 Danej540 is offline
Default Hydro lift retrofit on 129
Well I've had my 129 for about a year now and it's in pretty good shape. Anyway I picked up the ported hydro to put in the hydro lift. I have just about everything I need. I'm missing a swash in the ported trans. Will the insides og my non ported trans swap into the new one? And does anyone have and hydro lift related parts for sale? And where do I find gaskets? Any help would be appreciated!!
Old 10-25-2015, 11:11 AM
cubs-n-bxrs's Avatar
Was the ported pump you just purchased disassembled? If not why would you need a swash plate. Ported or not they all have swash plates. that is what makes them go forward/reverse and adjustable speed.
Old 10-26-2015, 10:32 PM
Yes it is disassembled. The guy used parts out of it for another cub. I found a 1450 with hydro lift and a 1250 as a package deal today I'm gonna go get them this weekend so I should have everything..
Old 10-27-2015, 10:40 AM
I used a 1250 rearend to put a hydraulic lift on a 129 and everything worked just fine.
Old 10-31-2015, 11:34 PM
well i got my parts tractors today and got the 1450 split and the trans off the rear end. and most of the brackets off. tomorrow im gonna split the 129 and put the ported trans and brackets on. im gonna try to get it done tomorrow because weekends are the only time i have time to do anything. so wish me luck!!!
Old 11-01-2015, 09:02 AM
Good luck on the upgrade.
Keep us posted on your progress.
Old 11-01-2015, 09:36 PM
ok well i got everything put on and i just swapped the transmissions so i could keep my original serial number. every thing went together fairly easy. i had to modify the lift handle a little bend the steel lines a little and the valve isnt mounted the best (i need to drill one hole). and i had to switch the flanges on the the transmissions. when i got it to a point to fire it up i have no crank... i replaced the ignition switch once becasue my girl friend broke the key off in it. (i jumped the solenoid) and it started fine. everything seems to be good besides the ignition problem. i have to order the trans/rear end gasket to put the 1450 back together. but so far im a happy camper!! i have a video of it running and lift working but idk if i can upload a video...
