Old 10-17-2015, 06:35 PM
Rguyer04 Rguyer04 is offline
Default 1282 ideas
I was thinking and wondering how hard would it be to take the armstrong lift off and put a hydraulic lift on this tractor. I was also wondering which is the better hitch to put on this tractor.
1862, 400 tiller, brinly 10'' plow
1282
Old 10-17-2015, 07:02 PM
CubDieselFan's Avatar
It might just be easier to find a 782.
Old 10-17-2015, 11:42 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
It WOULD be easier to find a 782, but usually find a ported hydro for around 100.00.
A single spool vale is about 40.00. The lift cylinders and hoses typically go around 25 bucks on ebay, lift handle could be built by you or purchased for not alot of money. Not sure about the cam for front implement lift but wouldn't imagine it to be much.
The rest is a few brackets, hoses. In short, around 250.00 you could have hydraulic lift on your 1282. You cant buy much of a 782 for that... least round here.
If you like your 1282 then get after it... dont see many 12's with hydraulic lift. ..
Old 10-17-2015, 11:48 PM
I might try to find another 1862 roller and use some of the parts to make mine better then use the power steering and lift from that on my 12.
1282
