Old 04-27-2010, 08:42 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Default What an awesome site here we have!!!!
Tonight, I decided to tackle the trouble spots on the newest arrival (the 102). I started by messing with the clutch.It seems the small clutch U bracket on the tower that holds the return bracket was severely trashed.So, I located another one as well as new pin and ordered it.Then, on to the really bad steering. It wouldn't turn left at all without severe pulling on the wheel. When you turned to the right,the shaft came outward. I decided to rip the old column out and check out the trouble. Thankfully,the online manuals were on here and I knew what to look for. As I took the column apart,I noticed several things wrong right off the bat. The one main bolt jam nut was missing,the follower was missing the lock nut,the zerk was removed and yellow old grease was still inside. They used a terrible looking grease inside as well. I immediately seen the bearings were all apart and the bottom balls were in the cap on the end. This was the reason the shaft came up when turning. We thoroughly cleaned it up,and that's when we realized the end cap was also missing the cotter key. We installed a new cotter. Now it functions very well and now works properly. I am getting a follower jam nut tomorrow and will be reinstalling the column this weekend. Thanks to the admins for having the technical sections here. Now... I need to get that clutch and brakes adjusted..
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 04-27-2010, 11:25 PM
ihnick's Avatar
ihnick ihnick is offline
i agree that this site is awesome. i'm on here all the time learning something new. and its organized way better then most forums. thanks guys
Nick.
Old 04-28-2010, 12:22 PM
You guys are correct! Only Cub Cadets is the best site on the net!
Old 04-28-2010, 02:52 PM
dyt4000's Avatar
dyt4000 dyt4000 is offline
I like to think so! =-)
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
