Old 09-25-2015, 10:54 AM
Frank1541 Frank1541 is offline
Default Re-Wiring my 1541
I have been looking for a project that combines my to hobbies. Working on my highly modified 1541 and electronics. So I am going to completely rewire the tractor.
My plan is to remove all the old switchs (except ignition) and replace them with solid state or at least water proof switches. All the switches will act as inputs to an Arduino controller using optical isolation. They will use 12 volts.
All the electrical components will be switched with relays. I am going to use a Parallax digital IO board for both functions, it has 8 inputs and 8 relays. The indicator lights will be controlled by a separate darlington array.
I am still trying to decide where I am going to mount the system. It will be around 6" by 8". My first thought is under the battery box.
The control logic will mimic the current system exactly, including all the safety systems. The software will include some diagnostics. I may add inputs for oil pressure / temp, voltage and maybe even RPMs.
About the only thing I am not completely sure of is the function of the current voltage sensor. I think it only senses voltage and lights the indicator if the voltage drops too low and has no regulation function.
I will take pictures and post as I work on it over the winter. I hope to install it next summer.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 09-25-2015, 11:21 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Sounds like a neat project! I have been toying with the idea of buying an arduino, I just don't know what I will do with it. I'll be watching!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 09-25-2015, 12:01 PM
For someone that has no clue what your talking about what is an "Arduino controller" ? What is the reason that you are doing this?
Old 09-25-2015, 12:23 PM
j4c11's Avatar
j4c11 j4c11 is offline
Hope to see your work on GitHub so we may all learn from it
Old 09-25-2015, 12:24 PM
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
How long will your finished project be able to stay in orbit before it has to re-enter the atmosphere for re-fueling?
May want to put some heat resistant tiles for re-entry if keeping the mower deck on, those decks are fairly thin metal and may heat up quite a bit.
Also, relocate the radio antenna, Houston has trouble making contact on Cyclops cubs due to that weird hood and headlight assembly.
Old 09-25-2015, 12:31 PM
jimbob200521's Avatar
Have you given any thought to a Raspberry PI instead of your Arduino controller idea? It would allow you to do more in the way of user interface such as a small touchscreen on the dash or mounted somewhere displaying live relevant data. Or maybe I'm just getting greedy haha
-Ryan
Old 09-25-2015, 12:43 PM
j4c11's Avatar
I don't think a Pi is the right choice for this project, it has to boot up and whatnot, and then do you keep it on and drain the battery or shut it down. A controller is more suitable.
Plus, the Pi it's more susceptible to the increased radiation and cosmic rays in orbit.
Old 09-25-2015, 12:49 PM
Very true, I did NOT think about that
I wasn't too concerned about the boot up time as it would take maybe a minute while the machine warms up. A nice little enclosure and the elements wouldn't be a problem but I do agree with your point in regards to simplicity. Just me wishful thinking of combining a computer with a Cub
Edit: I thought about getting one of those vehicle 12v coolers that goes between seats and somehow mounting it to the inside of my cab for snow duty. I could keep chains, gloves, tools, etc in it and it'd provide a nice little arm rest. Then if I could only move the hydro and lift controls to it I'd be 100% spoiled haha
-Ryan
Old 09-25-2015, 01:01 PM
j4c11's Avatar
If I'm understanding correctly, the OPs intention is to turn the safety switches into inputs, and so the controller logic would have to be functioning in order to be able to start the tractor. But how funny would it be to hear someone say "I'm waiting for my Cub to boot up"
Edit: you could probably get a Pi to talk to the Arduino controller...
Old 09-25-2015, 01:34 PM
Terry C's Avatar
Terry C Terry C is offline
This project sounds cool. I'm not a fan of adrino but I have programmed some PLCs for my CNC machines,for tool changers and misc functions.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
