Old 09-23-2015, 11:28 AM
vtjayman5 vtjayman5 is offline
Default 1440 with a 190-353-100
Hey Guys!
I'm new here as I just recently picked up a 1440 Cub Cadet garden tractor! I have done a bit or research on snow blowers / throwers that will fit it and it appears that only a 451 or a 551 will fit that unit. That said, I saw this model on Craigs List (190-353-100) and the seller swears that it will fit on my 1440 and run fine.
Does anyone here have any experience of this unit fitting on a 1440? Any advice would be appreciated! I can get photos if needed. In general, the 190-353-100 looks to be a bit lighter than the 451 and 551 units. I am in Vermont and plan to use this unit to blow my driveway. Nothing else. Probably about 1,200 sq ft.
Thanks!
When I get a moment, I'll be sure to get some photos of my tractor up here!
Jay
Old 09-23-2015, 11:51 AM
cubs-n-bxrs's Avatar
First off welcome to OCC. I just looked at the cub parts site and the 190-353-100 snow blower is PTO shaft driven. I don't think you can make it work on a 1440. The correct blower would be the 451 or 551 with the belt drive. I am pretty sure the 353 blower is made for the 3000 series tractor with the shaft driven PTO. Tell the 353 seller he should do a little research cuz he is full of poop.
Old 09-23-2015, 12:06 PM
What Kelly said. The 353 fits the following tractors.
Cub Cadet 3165 Tractor
Cub Cadet 3184 Tractor S/N 1J310G & Before
Cub Cadet 3184 Tractor S/N 1K010G & After
Cub Cadet 3185 Tractor
Cub Cadet 3186 Tractor
Cub Cadet 3204 Tractor
Cub Cadet 3205 Tractor
Cub Cadet 3206 Tractor S/N 1J310G & Before
Cub Cadet 3206 Tractor S/N 1K010G & After
Cub Cadet 3208 Tractor S/N 1J310G & Before
Cub Cadet 3208 Tractor S/N 1K010G & After
Cub Cadet 3225 Tractor
Cub Cadet 3235 Tractor S/N 1J310G & Before
Cub Cadet 3235 Tractor S/N 1K010G & After
Cub Cadet 3240 Tractor
Cub Cadet GT3100 Tractor
Cub Cadet GT3200 Tractor
Cub Cadet GT3204 Tractor
Cub Cadet GT3235 Tractor
Old 09-23-2015, 02:42 PM
Thanks for the responses guys. It does look like this thing is shaft driven off a pulley. Here's a crappy photo that shows some details. Sounds like I'm outta' luck though. I'll keep searching for that 451 or 551.
Jay
Old 09-23-2015, 03:48 PM
Jay
Just tossing this out for consideration, you may want to think about a plow. The blower is HEAVY and without hydraulic lift you may find it to be a serious workout for the right arm. Back in the day when I lived in New England I had a plow on a 1210 (very similar to a 1440) and a walk behind blower.
Old 09-24-2015, 12:07 PM
Hi Sam-
I have thought about a blade but I think I would run out of room quick unless I had a snow thrower of some type. Also, my drive way is not paved and somewhat rutted. I imagine that would make the blade a bit challenging to use.
I was hoping to put on some type of hydraulic assist if I do end up finding the proper blower attachment. I haven't researched that yet but would imagine there must be something out there that would fit...
Thanks for you thoughts. I appreciate it!
Jay
Old 09-24-2015, 12:25 PM
I don't know what model# that unit is in the pic but I can look at pics of a 353 unit in parts tree and see it is not the same. That appears to be a snow thrower. It might possibly be a haban unit. The way the pulley is arranged it might work on the 1440. Better pics would help. Any pics of the front view by chance? I just looked at the craigslist add and it appears to be a Haban snow thrower. It might possibly work on the 1440 being it was meant for wide frame tractors. I have never seen a single stage unit on a cyclops style tractor. Maybe someone else will chime in. Sam the man what do you think?
Old 09-25-2015, 04:32 PM
...And the plot thickens!
The guys swears it will fit a 1440. Another one of my concerns is that even if it fits, do I have to be concerned with the RPMs making sense? You know...that thrower spinning too slow or fast? Anyhow, if I end up getting the green light here that it will fit, I will be sure to document how it all works out for folks in this situation in the future!
Thanks!
Jay
Old 09-26-2015, 10:53 AM
I wish I had an answer for you. Better pics would help. For all I know it may be the proper thrower for a 1440. Guess you could take your tractor to the sellers place and have him prove that it fits and works.
Old 09-26-2015, 08:18 PM
johns cubs's Avatar
johns cubs johns cubs is offline
And voala, you got someone else to mount it for ya!
John
