Old 09-16-2015, 09:45 PM
Phil21502 Phil21502 is offline
Default Breather assembly
On my cub 127 I want to take the breather apart and make sure it's assembled the right way. I'm sure by other things on the tractor that it's installed with the oil seep hole on the top instead of the bottom. Anything to lookout for with this process or is it pretty much just pulling the nut off and taking a look? Thanks
Old 09-16-2015, 10:07 PM
timbo2's Avatar
timbo2 timbo2 is offline
It's pretty straightforward. You might have to pry or tap the cover a bit to get it loose after the nut is off. I've had a few stick. Then just pay attention to the order and orientation of the parts. Snapping pics is a good idea
- Tim
Old 09-16-2015, 11:11 PM
In this instance the service manual is your best friend for disassemble as well as assembly.
I would just add that when you tighten the nut on the breather cover, don't over tighten as it could possible distort the cover.
Old 09-20-2015, 06:58 PM
So do u have to remove parts from the engine to get the breather off? I was looking at it today and it looks like a bunch of stuff is in the way. Lol. Gonna tackle it Tuesday when I'm off.
Old 09-20-2015, 07:59 PM
timbo2's Avatar
you'll probably have to remove the carb. I don't know your model exactly but that's my guess.
- Tim
Old 09-20-2015, 08:16 PM
Nightow1 Nightow1 is offline
I have found this to be the Most true statement ever!!!! So many times I have taken something apart for repair, then put it back together only to discover that the PO had installed it wrong....
Old 09-22-2015, 04:35 PM
Well I got the breather off with the carb still on. The oil drain hole was plugged so hopefully that solves my breather smoke problem. Had to order a new gasket though for the cover so I'll have to wait for it to arrive before I can try it out.
Old 09-22-2015, 08:38 PM
If you don't mind my askin, did you just order the one gasket and what did you have to pay for it?
Thanks
Old 09-22-2015, 09:37 PM
Yeah just the outer cover casket. It was like $7.87 shipped. Cub cadet online.
Old 09-22-2015, 09:41 PM
Just saw on ur fb page where u have both covers for $6. And I prob would have them by the weekend too. Damn.
