Old 04-26-2010, 06:15 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Default Our 1st narrow frame just arrived home tonight...
102 with a replacement motor that is very sound. Grote light on back,headlights,3 point and spring assist. Deck has been patched,but still mows great. Have a couple trouble spots to iron out. 1 is when the steering is turned,the center shaft the steering wheel is attached to threads up out. Not great steering either. 2 is the clutch was replaced as well as throwout bearing and clutch spring,as well as the bracket the adjustment bolt goes through.That bracket hits the steering column when the clutch is pushed in. I am thinking it is the wrong piece as it is notched out but still contacts the box. May have some wiring issues as the battery wires are colored wrongly(red on neg,black on pos) needs to have a battery charger to fire up, but its sweet sounding. Is there a fix for the steering columns??
Oh, it was 300 bucks...
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 04-26-2010, 06:19 PM
That's a sharp 102, Pat! Have fun with it.
Old 04-26-2010, 07:11 PM
CBH's Avatar
CBH CBH is offline
Looks GREAT!
Old 04-26-2010, 07:26 PM
Nice 102 bignastyGS
Sweet trailer too :biggrin2.gif:
Old 04-26-2010, 07:47 PM
IHinIN IHinIN is offline
Nice 102. The steering column can be fixed. It sounds like the bearings in the steering box are shot. You should be able to get away with replacing the bearings and bearing cups.
Old 04-26-2010, 08:00 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
That's a beauty Pat!
Don't run it too much without fixing the steering. Maybe you can avoid a catastrophic failure if you get there early enough.
For the wiring, my 126 I think was positive ground. I still need to decode that mess! I'm thinking someone found a wrong direction starter-gen and went to a lot of effort to make it work on mine. It did work, and charge. The ammeter went backwards was the only thing wrong that I know of. Like I said, I'm not sure about the polarity, but I do know + was grounded, and - was attached to the solenoid. Definitely NOT factory.
Enjoy that new machine! I passed one up that the guy wanted $600 for, hadn't run for years, etc. Someone said it ought to be worth that, and apparently someone else agreed.
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 04-26-2010, 08:28 PM
wshytle wshytle is offline
bignasty-
I would just go through the steering and get it right now. Once you get it out (which is relatively easy) it's all bench work. Replacing the bearings isn't that costly and there are tricks to dressing up the follower stud. You need to check the plate with the bolt welded to it for flat. I have found several that are warped from the welding apparently. You can fix this in a shop press using a straight edge as you go to get it flat. I'd automatically get a new gasket too. You can even do an upgrade that's written up maybe in the library that uses a bearing and lock nut instead of the two jam nuts. It helps a lot with the steering. I'd do the same with the clutch. Go through it now and get it right and the tractor will be nice to you for many years to come. As far as that goes I'd do everything needed now so you'll always have a dependable cub. You got it for a great price so the money you saved can be put into all I've stated. It shouldn't take that much in it's condition.
Good luck with your "new" cub....Wayne
Old 04-26-2010, 08:57 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Pat,
Nice looking 102, and nice options. Head lights, tail light, 3-point, all desirable. If you don't mind, post your pictures here: http://cubcadet.1.forumer.com/index.php?showtopic=77
Old 04-27-2010, 08:52 AM
Great find Pat! Looks really good!
I like your tag on your Jeep too!
Old 04-27-2010, 11:44 AM
Jeff122's Avatar
Jeff122 Jeff122 is offline
Great find! Especially for $300. Good luck with it!
