Old 04-26-2010, 12:39 PM
karamia karamia is offline
Default Replacing flex discs on 982
Hello all. I'm a new member and this is my first post. I'm having a problem replacing the flex discs on the drive line. Mainly I can't figure out how to remove the drive shaft without shifting or (most likely from what I can see) removing the engine. The shaft extends into both the transmission and the engine couplers. There dose not seem to be enough play to move the shaft either way to effect removal. One good point about this is that if the discs were to experience catastrophic failure the shaft can't whip around destroying other components. Any help would be appreciated.
Also, I am looking for a chassis service manual for the 982.
Old 04-26-2010, 01:12 PM
Old 04-26-2010, 01:50 PM
ajgross ajgross is offline
Inactive Member
The easiest way is to unbolt the engine and slide it forward. Just remove the grille, remove the 6 bolts holding the engine down and them slide it forward. It should take anymore than 10 minutes.
AJ
Old 04-26-2010, 01:55 PM
Mountain Heritage's Avatar
Nice to see a fellow Canadian!
Old 04-26-2010, 06:09 PM
murphycc
Guest
Posts: n/a
I have swapped out drive shafts a dozen times without moving the motor. Pins are easily driven out of the shaft and couplers moved in on the shaft so the shaft can be removed.
Before anyone calls me an idiot for suggesting this method I will refer you for the MANUAL as the manual describes this method. (Yes I have been called an idiot for this suggestion)
You will need a good pin punch, not a standard flat punch.
Scott
Old 04-26-2010, 08:50 PM
The manual assumes you have a tractor that never spent a day of its life out in the elements. I don't like to hammer on things on the driveshaft unnecessarily since it isn't good for the bearings in the pump. I've done it both ways and found it easier to unbolt the engine and slide it forward than mess with the spirol pins unless the spirol pins are shot.
Old 04-26-2010, 09:23 PM
aagitch's Avatar
aagitch aagitch is offline
If it was me changing the discs, since you're going to have things apart anyway, i'd replaced all the spirol pins with new ones. I'd also take a look at the bushings on each end. If you need to change the discs because they're shot, most likely the bushings need replaced.
Old 04-26-2010, 09:53 PM
murphycc
Guest
Posts: n/a
Our approach may be different.
Once I take a drive shaft out for the first time it goes back in as new. If the shaft is good (no wear) then it gets wire wheeled and painted, pins get wire wheeled and a good coat of anti-sieze prior to instalation, bushings get replaced, rags replaced, bolts replaced. I've yet to have one that I did not take back out for some reason or another and once replaced it's a breeze to remove with everything clean and rust free and anti-sieze on the pins.
Scott
Old 04-27-2010, 12:46 AM
young enthusiest's Avatar
Hey guys, this new member with the 982 lives in the same town I go to school in. I've seen his 982... Really nice tractor, but it needs some TLC, and he is doing VERY well at repairing it. I agree on sliding the engine forward. I had to do tat to me 782. It is not hard
Old 04-27-2010, 03:04 AM
camarokidz28's Avatar
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Tags
982, drive shaft, flex discs
