Old 08-09-2015, 04:50 PM
Fitz14's Avatar
Fitz14 Fitz14 is offline
Default 782 won't move
I just got this 782 yesterday. It's been stored inside for ? years and looks it will clean up nice. I got the engine running and it sounds good with no smoke. The problem is, it won't move. The lift is working fine so I assume the pump is ok. When I try to go forward or reverse, It will lug the engine just a little but no movement. I'm afraid to hear what the problem might be, but if you guy have any ideas I would appreciate it. This is an early one built by International Harvester.
Old 08-09-2015, 05:01 PM
aagitch's Avatar
aagitch aagitch is offline
If it wasn't for you saying that the lift works, I was going to say it sounds like one of the roll pins for the driveshaft is sheered. Maybe it's possible there's still a sheered pin but the pump is spinning just enough to give you lift but not forward/reverse motion? hope you figure it out. I just brought home an IH built 782 that needs some serious TLC hope to get it looking as good as that one.
Adrian
2072 (789513)
Old 08-09-2015, 05:39 PM
bocephus1991's Avatar
Hope this doesn't sound stupid, but did you check the hydro oil level? Try changing it and the filter? That's where I'd start.
Brian
Old 08-09-2015, 05:43 PM
Fitz14's Avatar
I checked the spirol pins just turning it by hand. They seem to be tight. Another thing worth mentioning I guess. When I loaded and unloaded it off the trailer, it was free wheeling and easily pushed into the garage by hand. Now that I have had it running, I can't move it by hand. There's no lever to relieve the pressure on it.
Old 08-09-2015, 05:45 PM
Fitz14's Avatar
Yes, I did check the fluid. It was a quart and a half low. I filled it, but it didn't make any difference.
Old 08-09-2015, 05:52 PM
That is normal. Mine does the same thing.
I would take Relief (or check) valves out. Soak them overnight in something like PB Blaster. Before re-installing them, make sure the Plunger inside the valves travels "freely"
Old 08-09-2015, 07:47 PM
Brake locked up?
