Old 08-05-2015, 09:59 AM
blee128 blee128 is offline
Default Gears
I was pulling Saturday and due to the track conditions I pulled one round in 1st gear it was pulling good then all of a sudden it stopped and we couldn't get it out of gear after finally rocking it hard enough it came out got it off the track and it went fine in first tried pulling again and it started making a grinding noise so I stopped it it's only in first not second or third anybody know what this could be?
Old 08-05-2015, 11:05 AM
My guess is something important and probably expensive broke in the tranny.
Old 08-05-2015, 12:37 PM
cubs-n-bxrs's Avatar
I guess I would pop the shifter/cover off and take a look see into the tranny. It will probably become obvious what the culprit is.
Old 08-05-2015, 12:59 PM
I pulled it off and everything looks normal the only thing I can figure by the looks of things is the shift forks were stretching and it was trying to come out of gear they were a little wide so I fixed it and we will see next time
Old 08-05-2015, 05:19 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
if it did any damage it would have been to the 1st - R sliding gear (rear fork) not uncommon to break a tooth off since its such a small gear. its a good idea to weld the fork so it can't spread where the shifter goes in. also look at the fork. they tend to break on the underside where they fasten to the shift rail
