Old 04-24-2010, 04:53 PM
c02cutter's Avatar
c02cutter c02cutter is offline
Default Diameter of bolt pattern
Does anyone happen to know the diameter of the bolt pattern highlighted in red here? Want to laser cut some wheelie bars knowing what the diameter there is suppose to be would be a big help. Can't find it in any docs I have seen.
Old 04-24-2010, 05:11 PM
I made a paper pattern for mine, pulled three bolts and placed the paper over the holes, the dirt in the holes made a mark I could follow.. All I used was a C shaped piece of 1/8 plate.....built a tab off it to attach the lower bar, and mounted the upper bar to the place where the rear hitch would have pivoted on my 122. Simple, light, and it works.
Old 04-24-2010, 05:46 PM
c02cutter's Avatar
truckntran, you were suppose to make it easy on me... I was cheating by asking. Nice explanation on how to get it though, Thank you.
Old 04-24-2010, 10:29 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
Seems to me like you could find it mathematically if you only knew the distance between two bolts. There are 6 of them and they are on a 60 degree spacing. You are building equilateral triangles, so the distance between two bolts "should" be half the diameter of the bolt circle.
I've had a couple brewskis mowing the yard (first time this year!) this afternoon/evening, so if this sounds like BS, it probably is. It makes sense to me though.
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 04-24-2010, 11:07 PM
I'm pretty sure that's right.
Old 04-25-2010, 12:29 AM
murphycc
Guest
Posts: n/a
Or you could just spent the $12 and order a couple of gaskets, they probably need changin anyway....I'm simple like that.
Scott
