Old 08-01-2015, 10:43 AM
samiam44 samiam44 is offline
Default Paint suggestions for a 1650
Good morning,
I see lots of different threads. HOW MUCH paint will I need?? I would like to do a restoration single stage urethane. The fenders and 44a mower deck, wheel, seat, etc will be sand blasted and epoxy primed.
Probably a coat of primer-surfacer with a top sanding too. I want nice and durable too. It's not going to be a parade tractor- but used in the yard.
Keep looking online trying to find a good discount place which carries ppt, dupont etc. I was considering Kirker primers.
Michael
Old 08-01-2015, 11:55 AM
Yellow paint has the worst coverage of any color, the pigment is thin so more coats are needed to get full coverage. I work in a shop and regardless of the brand yellow paint is a pita, when I paint a tractor I buy a gallon of yellow and a gallon of white and I use all the yellow and about 2/3 of the white. The paint I recommend is the case/ih paint, its made by valspar and looks incredible when sprayed properly and it won't break the bank like ppg or Dupont paint. To help the coverage issue you want to buy a primer that's really light grey or white, this will allow the yellow to cover faster with less coats.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-01-2015, 11:58 AM
thanks tim!!
Old 08-01-2015, 03:32 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Tim,
Is the case IH paint enamel based or urethane based?
Jay
Proud owner of the following:
Old 08-01-2015, 04:05 PM
Originally Posted by jaynjeep View Post
Tim,
its enamel
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-01-2015, 09:31 PM
jaynjeep's Avatar
its enamel
Ok thanks! I used some Case IH argent silver enamel a while back and it worked out really nice.. Just used some universal hardener and thinner in it. Wanted to make sure the yellow and white was the same deal.
Jay
