Old 07-31-2015, 04:23 PM
Default NF hydraulic pump question
Saw another thread about front seal replacement on one of these. I have one and have a question too. The control handle for it is tight and has no return to center. I saw another thread about a W spring on here also. I'm assuming the W spring is for the return of the handle or is for something else inside the pump?
Old 07-31-2015, 05:44 PM
IHinIN IHinIN is offline
Attachment 67269
Yes, the W spring centers the valve when you let go of the handle.
Old 07-31-2015, 09:29 PM
Thanks Adam. I guess I will have to take it apart and see what's going on. Spring might be ok, it's just pretty tough to move and doesn't center itself
Old 08-02-2015, 12:20 AM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Hopefully the valve and the bore it sits in only need some cleanup with some Scotch-Brite. A nice free fix.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
