Old 07-29-2015, 06:55 PM
2155owner's Avatar
2155owner 2155owner is offline
Default 2155 Battery not charging
Put new battery in it . Started twice won't start. Jumped with truck started cut one acre of grass. Turned off. Won't start back up. If jumped with truck will start.
help.....
Old 07-29-2015, 07:02 PM
First........welcome to OCC...........
Do you own and know how to use a DVM or VOM....???
Old 07-29-2015, 07:49 PM
2155owner's Avatar
Default 2155 battery not charging
Yes I have that meter.
Dan
Old 07-29-2015, 08:11 PM
With the engine running at WOT, measure the voltage at the battery terminals and report back.
Old 07-29-2015, 08:18 PM
2155owner's Avatar
It will be a couple days....
Old 07-29-2015, 08:28 PM
Report back with your findings.
Old 07-31-2015, 07:01 PM
2155owner's Avatar
Battery voltage at wot is 14.2
Old 07-31-2015, 07:30 PM
Clarify that please.
Are you saying it rolls over OK but will not start up
OR....it won't roll over.
Old 07-31-2015, 08:20 PM
2155owner's Avatar
Jumped mower from truck battery. Put tractor in w o t tested battery . Reading was 14.2 .
Old 07-31-2015, 09:19 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
perhaps you got a defective battery???? 14.2 volts should be charging the battery. do you have a battery charger? i would try charging the battery,and see if that works,if not bring the battery back for a exchange
