Old 07-27-2015, 02:44 PM
johns cubs's Avatar
johns cubs johns cubs is offline
Default Hydro pump front seal
Hows every body doing? Wondering if anyone has ever had their hydrollic pump apart to change the front seal? And if there is anyway to beef it up while i have it apart?
John
Old 07-27-2015, 03:26 PM
What are you working on? As far as changing the seal for the charge pump, it's an easy job. All covered in the service manual.
Old 07-31-2015, 03:04 PM
johns cubs's Avatar
Thanks Sam! I got it figured out. Working on my 104 with dozer blade. The hydro pump shaft was leaking like a siv! Was wondering if i needed to pull pump apart to change seal.
Lots of work to be done.
John
Old 07-31-2015, 03:40 PM
John
I thought you were talking about the front seal for a Hydro.
Old 07-31-2015, 04:44 PM
Terry C's Avatar
Terry C Terry C is offline
John
So did I till he said 104
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-31-2015, 05:06 PM
johns cubs's Avatar
Sorry guys! Next time i will try to be clearer! I get in such a hurry that i forget.
Boy this thing is a little beast! We have moved tons of dirt already! With lots more to go! Wish i either had narrow wheels and tired for front or the blade to be about 4 inchs wider so tires wouldn't hit side of dirt pile
John
Old 07-31-2015, 05:10 PM
Terry C's Avatar
I can turn one set of front wheels around so the offset is in. If you try it just watch the valve stem
Terry
3225
Old 07-31-2015, 05:41 PM
johns cubs's Avatar
Never thought of that! I had one of those e-z stear knobs on the steering wheel til tire hit side of pile and it ripped it out of my hand and whacked my wrist bone!! Worst part is i kinda seen it coming!!
John
Old 08-10-2015, 11:57 AM
johns cubs's Avatar
I got the seal leak fixed and dont see anything else leaking, but for some reason if i shut tractor off the dozer blade seeps down. Fluid level in pump is same as when i filled it. Any help is appreciated!!
John
Old 08-10-2015, 12:03 PM
johns cubs's Avatar
Its already turned that way. I will have to keep my eyes open for a set of narrow tires and wheels. Or maybe widen my blade? We'll have to see how it goes.
John
