Old 07-26-2015, 08:24 PM
kyleb179 kyleb179 is offline
Default Working on my 100
Hi all. Been putting together a 100 from a few parts machines and i am happy to say i have a moving operating wood-hauling machine in her original patina
I recently got some Ag tires that go on the front, mounted on rims, that have a 4 lug pattern. Does any other cub have a spindle that i can upgrade to using, or is there a hub out there i can use??
i will post some pictures tomorrow. too dark for them now.
thanks!
Old 07-26-2015, 09:10 PM
Terry C's Avatar
Terry C Terry C is offline
Xtreme motor works sells a hub set up that you weld on. I believe you cut your axle at the 90 bend and weld on theirs.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-26-2015, 09:37 PM
Tim.E's Avatar
Tim.E Tim.E is offline
I don't know of any hub that will work for your purpose without modification.If there is something out there, I would like to find it.Azusa makes some hubs that might work with a little modification.
Some people cut off their spindles and weld trailer stub axles to them.
Or you could fabricate some like I used on my 106 refurb/mod.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 07-27-2015, 07:22 AM
cool guys, thanks, i will look into those options later
Old 07-27-2015, 07:41 AM
OldSkull's Avatar
OldSkull OldSkull is offline
This have been post many time:http://www.pf-engineering.com/spindle-upgrade from there you can figure it out.
Gilles.
1963 100 (red)/in storage
Old 07-27-2015, 07:47 AM
Here is some pictures. The first picture is the day i brought it home without a motor. The 100 hood mounting holes are shot, that's why it has a 70 hood on it in the second picture. I sourced a motor for it in a non running state, and it was very rough to say the least. Cleaned/ lapped/ reset the valves, new head gasket+ bolts, new points and condensor, she fired off without a hitch! This machine has fenders, lights front/rear, creeper, reflectors, 3PH, and i acquired AG's at a tractor show a few weeks ago!
Old 07-27-2015, 08:08 AM
OldSkull's Avatar
Look like you build yourself a nice little workhorse
Gilles.
