Old 07-22-2015, 09:36 PM
cubcadetguy123's Avatar
cubcadetguy123 cubcadetguy123 is offline
Default Paint
http://www.onlycubcadets.net/forum/a...pictureid=6390
This is a can of paint that i picked up today. I plan on using on the wheels and hood of my 73. It's called "Cadet White" 759-3264. Is there a difference between the paint on the new cubs and the paint on the older ones?
Old 07-23-2015, 12:44 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Default Paint
There were three different whites from 1961 to 1989.. IH 901, IH 902, and IH 935.. the Cadet white you have is the same as the IH 935..
The 902 white would be correct for a 73 I believe, but what you have is close and would look fine im sure.
There is a nice chart in the tech section of this forum
Here is a link for you
http://www.onlycubcadets.net/forum/showthread.php?t=19
Good luck and have fun!!
Jay
Proud owner of the following:
Old 07-24-2015, 08:38 AM
How about the yellow? Are they all the same or slight variations?
Old 07-24-2015, 07:36 PM
Yellow is the same through the IH cubs. See jays post for the chart.
Old 07-24-2015, 11:29 PM
jaynjeep's Avatar
Like Alvy said, they are all supposed to be 483 Federal Yellow thru 1989.. It does vary a bit from brand to brand or depending on how heavy the guys the quys fingers are when mixing the paint..
Use the link above, Roland put together a nice chart with the codes and part numbers for various brands of paint..
Jay
Old 09-09-2018, 12:58 PM
kyumanaz's Avatar
kyumanaz kyumanaz is offline
Is it like blasphemy to paint a 1970 127 IH red and white?
[ATTACH]disassembly 4.jpg[/ATTACH]
Old 09-09-2018, 01:30 PM
Depends on who you ask!!
Old 09-09-2018, 02:08 PM
john hall's Avatar
[QUOTE=kyumanaz;465847]Is it like blasphemy to paint a 1970 127 IH red and white?
QUOTE]
Its just paint, it comes back off. Any paint is better than rust. If its not a pristine original condition machine worth preserving as is, then have at it. Drills, welders, torches, plasma cutters, discarding USEABLE original parts---then you have entered the realm of blasphemy.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-09-2018, 04:21 PM
farmall fred's Avatar
farmall fred farmall fred is offline
Your machine, paint it to suit what you want it to look like. I have no issue with people painting a Cub red and white if that is what they want. When I painted my 1872 project I built I painted it red with white wheels and a black frame. It suits me and most people like it.
The ones that do not, well I do not care. I built it to suit me and I am happy with it. I say go for it. and good luck.
Old 09-09-2018, 07:50 PM
I INSIST that my Cub Cadets remain absolutely factory stock!!
The yellow paint in this pic is "old" CAT yellow directly from a Caterpillar dealer,,,
For comparison,, the mower deck is the original powder coat, it was not painted,,,
