Old 07-18-2015, 09:24 PM
fer100's Avatar
fer100 fer100 is offline
Default Mower deck paint
can anyone tell me the name of the paint that coats the underneath of the mower deck to keep the grass for sticking to the deck. I cann't keep bottom clean grass sticks gives a bad cut. Rich
,1 Ariens 934 Hydro with cyclone rake
Old 07-18-2015, 10:18 PM
Unobtaineolum
Old 07-18-2015, 10:54 PM
cc_bob cc_bob is offline
You're probably thinking of SlipPlate (paint with graphite in it).
CLICK
My FIL used it on his Kubota and it seemed to work for a little while but quickly wore off.
I like to keep em running and work them.
1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors.
Old 07-18-2015, 11:28 PM
bocephus1991's Avatar
Slip plate will eventually wear off. Just expoy primer and paint it like the rest of the tractor.
Brian
Old 07-19-2015, 01:13 AM
you want the underside of the deck to be as smooth as possible, rough surfaces make it easier for the grass to stick that's why bed liner or similar coatings are a bad idea. flat paint is also a no no, use hi gloss paint for best results.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-19-2015, 01:23 AM
I agree, but I'm gonna take it a step further.... I have found its just like a plow. Polished smooth, no rust, no paint is best. However... it's tough to keep the underside of a deck that way because grass is alive. Even when it's dry, it's wet.
Old 07-19-2015, 10:28 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I tried the slip paint, it didn't last long.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 07-19-2015, 10:46 AM
This maybe an option..... http://www.vansicklepaint.com/ezslide/index.html
Old 07-19-2015, 11:04 AM
Shrewcub's Avatar
I used the rattle can. Got it at TSC. Out of curiosity what deck are we talking about?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 07-21-2015, 12:00 AM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
I brush on a thick coat of black paint about every 2 years.
I lost track of what I own a long time ago!
