Old 07-16-2015, 10:04 AM
sawdustdad's Avatar
Default Engine RPMs...
I was starting to get frustrated with my 1450 with a 50A mower deck not cutting the grass very well. Leaving uncut grass, having to slow way down to get a clean cut. Just seemed like it wasn't cuttin' the mustard any more, so to speak.
Got out the optical tach to check engine RPMs, and discovered that with the deck engaged, it was only running 2850RPM at full throttle! No wonder it was lacking in the grass eradication category.
Upon further inspection, the throttle cable has slipped through the cable clamp on the side of the engine and it wasn't opening up the throttle all the way. After a few minutes of tinkering, got it back up to 3600RPM, tweaked the carb a bit to settle out some hunting, and voila! Grass killer back in action.
Cut the front yard, very pleased now. All of this is just to show that without a tach (about $12 shipped on ebay) it's hard to know what your engine is doing. Should really use one every time you work on the engine to confirm that it's running at spec.
Old 07-16-2015, 10:18 AM
CubDieselFan's Avatar
Thanks for the tip. That is one thing that I do not have yet(tach).
Old 07-16-2015, 10:41 AM
RedHawCadet RedHawCadet is offline
Very helpful info!
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 07-16-2015, 12:08 PM
Leadslingingdaddy's Avatar
I'm going to invest in a Tiny Tach for my zero turn...Seem to be a viable piece of equipment...
Old 07-16-2015, 03:39 PM
Darrell Darrell is offline
Would you have a link to the tach you bought ??? I did a search for Optical Tachometer on Ebay and the cheaper tach's shipped from China.
Old 07-16-2015, 03:45 PM
j4c11's Avatar
j4c11 j4c11 is offline
Here's one on Amazon that I use:
http://www.amazon.com/CyberTech-Digi...rds=photo+tach
Old 07-16-2015, 03:53 PM
Originally Posted by j4c11 View Post
Thanks for the link !!!
Old 07-16-2015, 08:32 PM
bocephus1991's Avatar
That'd be handy! Thanks for sharing!
Brian
Old 07-17-2015, 09:16 PM
sawdustdad's Avatar
Here's the one I bought on ebay.
http://www.ebay.com/itm/111663312765...%3AMEBIDX%3AIT
$12.39 & free shipping from CA.
The one on Amazon is probably identical.
Old 07-19-2015, 09:27 AM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
I prefer the $12 optical tach as found on eBay vs the Tiny Tach. I've got both, and also the B&S vibration tach. While the $40 Tiny Tach is nice because you always see the hours and RPM, the internal battery lasts only about five years and is not replaceable.
