Old 07-16-2015, 08:53 AM
rdehli rdehli is offline
Default Hydro Whine
I have noticed over the years of collecting tractors , etc. some tractors the hydr is louder than others etc, what actually causes the hydro to make noise etc, and why are some louder than others ? thnx in advance
Old 07-16-2015, 12:10 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Can be a multiple of things. When I picked up an 1872 about 2 years ago. The hydro whine was so loud you swear you need hearing protectors when running it. I found out shortly after getting it that some of the bolts on the tunnel cover were loose. With the tractor running, downward pressure on the cover made this noise from to a normal level. With the cover loose, it was acting like a sounding board and amplifying the hydro noise.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 07-16-2015, 12:46 PM
Terry C's Avatar
Terry C Terry C is offline
Cavitation (air bubbles, foaming oil) I think but you better wait for an expert
That's what someone told me
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-16-2015, 01:40 PM
The wrong type of oil will do it also.
Old 07-16-2015, 09:07 PM
Olesalt Olesalt is offline
Default win of hydro
Originally Posted by rdehli View Post
I have noticed over the years of collecting tractors , etc. some tractors the hydro is louder than others etc, what actually causes the hydro to make noise etc, and why are some louder than others ? thnx in advance
Now a sure fired way to eliminate your Hydro whine is to load the whiner in your truck or on a trailer,
and bring it to me. make sure you leave the keys too, and when you get back home you wont here that awful Hydro whine. problem solved....
Always trying to help
Old 07-16-2015, 09:24 PM
bocephus1991's Avatar
My 1211 doesn't whine. But I haven't ever heard a hydro combine that didn't!
Brian
Old 07-16-2015, 09:48 PM
Terry C's Avatar
My 129 and 123 are totally silent unless you really throw the lever fast. My 149 whines most of the time.
Terry
3225
Old 07-16-2015, 10:21 PM
Tankman's Avatar
Tankman Tankman is offline
My 1641 and I both like wine. You don't???
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 07-16-2015, 11:06 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Ive had them both.. some whine and some don't.. I always figured the whine may be due to a worn pump or the wrong oil.. But like one other member said... every hydro IH combine or farm tractor that I ever operated whines like crazy...yet they perform very well..
Jay
Proud owner of the following:
Old 07-16-2015, 11:29 PM
CubDieselFan's Avatar
My 1864 whined terribly when I got it. You had to wear ear plugs it was so loud. I changed the fluid and filter and cleaned the rear out and that cured it.
