Old 07-14-2015, 01:07 AM
bonnieclyde100 bonnieclyde100 is offline
Default Ported pumps
did any 127 cadets come with ported pumps and if not can one be put on or do i need to go with an extra pump hooked to the engine? i am wanting to hydraulics on the lift to go with my sleeve hitch. i may also try the double helper spring to do the job.
Old 07-14-2015, 01:37 AM
cubby102's Avatar
cubby102 cubby102 is offline
They did not come factory... they can be added. Essentially the same pump it will bolt right up but running the lines is going to be cramped because it's a narrow frame but it has been done many times.
Old 07-14-2015, 05:00 PM
do you think its worth it or would you suggest an extra engine run pump?
Old 07-14-2015, 05:08 PM
cubby102's Avatar
If I were gonna do it is install a ported..much cheaper
Old 07-14-2015, 05:56 PM
Merk Merk is offline
X2
Project Uncle Dick
Cub Cadet 70
Old 07-15-2015, 12:04 AM
thanks guys cheaper does sound better.
