Old 07-11-2015, 08:40 PM
cjet69's Avatar
cjet69 cjet69 is offline
Default Cub Cadet 124 Freebie
Just brought home this 124 freebie. Its not running at this time, but the engine is loose. Need to check things out and see what the problems are. The serial # is 250xxx which I believe makes it a 1968 model.
CC 1450, 44A deck, #2 tiller, 42" plow/blade
CC 124
CC 1220
#2 Cart
Old 07-11-2015, 08:48 PM
You did great for free I see a rear lift, wheel weights and headlights
Old 07-11-2015, 09:15 PM
cjet69's Avatar
I charged the battery up, shot some gas in the carb, and it fired up. The carb looks like it has some gummy gas residue in the throat so I will be pulling it down for a good cleaning.
CC 124
CC 1220
#2 Cart
Old 07-11-2015, 09:21 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
great deal,i see alot of potential there
Old 07-12-2015, 05:03 AM
Grampie Grampie is offline
That's one super sweet deal! Congrats to you!
Old 07-12-2015, 06:21 AM
randallc randallc is offline
Enjoy that one: Those deals just don't come along very often, especially when you can shoot a little gas to them and fire them up.
Old 07-12-2015, 07:14 PM
cjet69's Avatar
I pulled the carb and ran it through the sonic cleaner. It cleaned up good. I put a new fuel line on as the old one was rubbing on the throttle shaft. I put some fuel in the tank and within a couple cranks she was up and running. It seems to run pretty good. All of the gears work in the trans. the steering could be tightened up a little, but overall its a good sound tractor.
CC 124
CC 1220
#2 Cart
Old 07-12-2015, 07:24 PM
Billy-O's Avatar
Billy-O Billy-O is offline
That's a sweet deal! Great on the start up! Tell me about your sonic cleaner....my eyes bright and ears perked!
Plow blade
#2 Cart
QA36 snowthower
Old 07-12-2015, 07:40 PM
cjet69's Avatar
It a cheap one from Harbor Freight. I use straight Simple Green in it and have pretty good results. It amazes me how much crud it will remove.
CC 124
CC 1220
#2 Cart
Old 07-12-2015, 08:40 PM
cjet69's Avatar
Short vid of the first run.
https://www.youtube.com/watch?v=thMw4c_K9G8
CC 124
CC 1220
#2 Cart
